Philster
- Sep 15, 2009
- 3,342
I have a 26' 1996 Scarab. 25 pitch prop. I bought it this past fall and love it, but I had a feeling it was overpropped, just from reading about props here and doing some math. I could never come up with an answer that was recommending anything bigger than a 24 pitch. Based on power, weight, gearing I was always getting 23p or 24p. Mostly 23p.
Well, she's been out twice, and she makes 4400 to 4500 RPM at WOT. I got her to 60 (barely). She does 57-58 easily and she is at a wall at about 4400 RPM or a little more. Well... maybe she has other issues, right? Nope. She was surveyed and checked out on all fronts. Good compression. All good.
Maybe.. MAYBE I could have leaned on her longer, but she was at a wall. One run was totally flat water... and one was light chop.
I have a feeling anyway about the prop... Then I find two things that scream 'too much prop'!
First is a video of my identical boat doing 64. The video shows the tach and speedo and conditions. At 5000 RPM, she is at 64 MPH.
http://www.youtube.com/watch?v=H6iIq4WWugQ&NR=1
Then I find the factory spec sheet via Wellcraft: She came with a 23-pitch prop. She did 61 at 4800 RPM as the advertised test speed identically equipped (except for the prop).
I'm looking for a modern, 23p prop. Off I go!
