*update 9/3* 1969 Chrysler 55hp Model 5555... silt "cemented" my shift rod in LU!
Hi Folks...
Newbie to anything and everything "Boat" related, including outboards = this is my first post!
I have already found a wealth of info here, and I am wondering if I may pick some more of your minds!
I just bought a 1969 North American 15ft Tri-Hull and it came w/ a 1969 Chrysler 55HP Model 5555.
The boat was last run about 9yrs ago at which time, the fuel system (carb, hoses, ...) were rebuild, run once to make sure all was good and then put away inside a garage for storage. I just bought the boat and looks to have VERY few hours on it!
One query right off the bat, does this model have an alternator or not? Help me determine the right "type" of battery to get.
ANYWAYS
I need to buy a battery (any recommendations?) to be able to start the motor... any tips or advice? I know the fuel mix ratio should be 50:1 and to put the lower unit in a barrel... ![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Also, I noticed under the dash where the key ignition switch is located, the following wires were NOT hooked up: purple, orange and black... leave these along or do these need to be hooked up to the ignition switch as well? (Yes, I am in the process of ordering a manual
Thank you in advance and looking forward to enjoying this new adventure!![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Hi Folks...
ANYWAYS
