dinghyracer
- Jun 1, 2015
- 19
Hi Guys,
I have a 60hp Johnson 2 stroke that seems to be a bit unpredictable to cold start. Some days when I go out it will start up first turn and other times it will take 10 minutes to get it running (but I usually get it running in 2 minutes) When it does the latter of the two it will fire up for a few seconds and then just cut out or else start up enough to disengage the starter but the engine will not actually get going. When it starts up it runs perfectly all day and will restart flawlessly even when left for a few hours
My cold start procedure is:
Squeeze the primer bulb until it is firm
Turn the key so ignition is on
Push the key in 8 times to prime
Lift the fast idle lever
Turn key to start
( I know you are supposed to to push the key in to primer and crank at the same time but that never seems to work for me)
This is so frustrating to me because I work with 4 strokes during the summer and they always start up straight away without any fiddly starting procedures.
Greg
Turn key to start
Greg
