Re: Universal tower question
I have exactly the same boat. I just got it toward the end of this season and the last thing I did before winter was put a tower on it. I got the DIYWake Pro Universal Swoop Tower in polished aluminum. They used to have pictures of it on a Reinell on the website before they got rid of the package deals. It fits pretty good, but it does hit right on the curved part of the hull. Between the fact that the tower allows for the mounts to hit at whatever angle is necessary and the rubber pads it fits well.
It was a bit of a pain to put in, you better have a strong buddy on hand and either be 6'+ or have a step ladder you can get in the boat. The way it is designed is the legs slide into the ladder top and you have to drill holes through the legs through the existing holes in the ladder top to bolt it together. As narrow as the 185 is you have to cut about 4-5 inches off of each leg since they run long since it is a universal fit. I went ahead and cut some 4x6 pieces of 1/2" ply to back the hull.
What I did was pre-drill the fiberglass (I ran the drill backwards when I went through the glass to avoid chipping the gel coat) and chamfer the edges with a slightly larger bit to avoid stress cracks. Then I used some construction adhesive to adhere the plywood and after setting overnight I drilled through the wood and and then bolted the mounts on using the supplied backing plates and lock nuts the were plenty long enough.
I used it twice before the end of the season and it worked great, and I checked the fasteners when I winterized and everything was still tight. I wish I had a picture of the tower, but I didn't take any before the first trip out (I was 2hrs late as it took 3hrs longer than I budgeted to get it together), and my camera got destroyed on my second outing. I have it collapsed and covered, but I will try to take a picture in the morning of the mounting points for you. Based on price and how well it worked I would buy it again, but I haven't ever installed a tower before so I can't say how the experience compares.
It took me about 3hrs of mock-up and 30 minutes of drilling one day. Then about 30 minutes to cut the wood blocking and glue it in. The next day it took about 30 minutes to drill the wood and 2+hrs to bolt the mounts up (I couldn't keep a wrench on the damn nuts for the life of me). The legs were still too long so I spent another 1/2hr trimming them as second time, and 20 minutes to mock them up properly. With help we had the holes drilled in the top and bolted up in another 30 minutes and were ready to clean up and hit the lake. Take more care in cleaning up than I did, as I ended up getting 3 different shards of aluminum in my foot that day although luckily I was the only one.
