caddylover
- Apr 11, 2012
- 49
Good day. i have a 91 merc alpha 1 gen 2 and I have ordered all my parts for the mentioned replacement. My exhaust bellows is ripped and upon further inspection i noticed that the ujoint bellows is starting to fray just a little as i can see a bit of the spiral wire. The boat used to be used alot when we were younger but now that we are older and have small kids we are lucky to get it out in the water for more than two weeks at a time.
In any case, i am going to tackle this myself and see if i can get it done. I am pretty mechanically inclined as i've changed out rads, waterpumps, alternators, brakes etc on other vehicles, but never done anything on a boat except adjust the idle screw on the carb, lol.
My biggest question is taking off the bell housing after removing the outdrive. I need to get a bit of room to fish the wires through the transom for the trim sender/limiter. I am not going to change out the shift cable as that was done not too long ago from what i can remember. So, once i take off the hinge pins and take off the exhaust and ujoint bellows from the transom end, am i able to just pull that housing off and it will give me the foot or two of room that i need to place the housing on a stool or something? OR do i need to disconnect the shift cable from inside the boat first so i can pull some of the wire through after loosening the worm gear clamp from the shift cable bellows?
If i have to disconnect the shift cable from the inside, will i have to do any adjustments when connecting it back together?
thx in advance.
thx in advance.
