When I tried to start up my Mercury outboard 200HP on my Sea Pro 21, the starter did not turn with the gear in Neutral. The day before everything worked fine. The starter turned and the motor cranked up as expected. What could be wrong with it? The ignition switch seems working fine. How can I check out the solenoid? Whatelse I should check for? Thanks.
Hi, Thanks to all those suggestions. I finally located the problem. It was the throttle control. After lubricating it, I was able to start the motor. The selenoid is good with the suggested test. Thanks again.
