Donald Terrell
- Jul 17, 2004
- 69
I finally got to work and with the help of my Pop, performed a complete, proper tune up. She runs great now, new points,condenser,rotor,cap, wires, and plugs. Checked dwell and timing which was right on. I went through the gas system first, doing a carb rebuild, checking antisiphon, fuel pump etc. I still have a shifting issue, but I wanted to get it running good before I do the transom service as I have the transom service kit and intend on building a outdrive support as seen on one of these topics, I have the links. It was nearly impossible to get it out of forward gear into neautral today As long as I have owned the boat, when you first go into forward, you would hear a thud, the clutch dog engaging maybe? Nine years ago I had it in the shop and the marina adjusted something, shift cable I think, and for a couple seasons it didn't make that thud noise, but today it was most noticable and would thud several times unless you could throttle up quickly. I would like to know what the marina done to tighten the shift cable. I hope it is not to late and I have ruined the gearset. I have studied on removing the outdrive and viewed the pictures posted by Boatgrunt. I am hoping to find out what is wrong when I remove the drive, maybe corrosion around the bellcrank. Any advice on this shifting issue would be greatly apreciated. I don't have the alignment tool or the puller to remove the gimball bearing. If I take measurements of where the trim cylinders are and make sure the trailer is not moved, can I put the drive back on without the alignment tool? I have never removed an outdrive, I have the actual OMC service manual and an after market brand manual. I have a good understanding of mechanics and how things work. I just wanted to post that I have made some progress as she is running 45 mph at WOT sounding good. Thanks evryone!!!! Any response to my shifting issue would be great. I have read stuarts article and many post related to the elusive OMC shift adjustment. Thanks to eBasic Power, my parts came the very next day, we are in the same state.
