I have an unusual situation. I was given a '74 Johnson (model 135ESL74B) to offset a debt, but it came w/ no controls. They were whacked off. I have a short length of wire extending out of the motor housing that plugs into the harness w/ the red plug.
My money is tight, so before I purchase a control box and cables, I would like to get the motor running. Is it possible to do w/out the complete control/ignition wiring in place?
I've tried to jump 12v from the feed side of the starter solenoid to the small terminal on the solenoid w/ a start button. I only get one click and then nothing else. The pinion gear doesn't extend.
I, also, tried to jump from the feed side of the solenoid directly to the hot side of the starter motor. I activated the pinion for a second and then nothing. Holding the start button down does nothing.
Do I need to wire some of the cut wires together to make this work?
Thanks
Thanks
