oldrudedude
- Jul 3, 2008
- 480
1979 Johnson 140
The powerhead is blown so I am removing the LU for parts.
I have:
1. Removed the bolt under the carbs holding the shift rod
2: Removed the trim tab bolt as well as the bolt that the trim tab hides
3: Removed The other four visible bolts securing the LU
I have managed to get the LU to drop down only a couple millimeters.
It will rock slightly with pressure from my hand as if something else in the forward part of the LU is holding it.
Is there something on the powerhead end of the drive shaft that has to be removed?
I have:
