I have a 95 Cajun 19.5 foot fish and ski with a 115 hp evinrude with a 3 blade 12.75 dia x 21 pitch prop. Boat is rated for 195 hp I believe it originally had a 150 fast strike v6 engine.
Problem: I gun it out of the hole and it struggles (motor trimmed in) start trimming out and on slick water I can hit the sweet spot and the rpm's will start to rise up to 3600 and the back of the boat will come up and the nose will fall then I will continue trimming the motor up then the rpm's will either run away or start to fall off. I call it cavitation but some call it ventalation, I don't care I just know it falls flat and I have to back out of it and jump back into it. Sometimes it feels like a motor performance issue but it never comes up on plane without me trimming up and down the feathering the throttle to keep the prop grabbing water. The motor is a little high, about 3 inches above the bottom of the hull but the bottom of the hull end about a foot before the transom. I have tried the doel fin the motor is all the way down. I don't know the top speed but I can achieve 4900 to 5300 rpm's depending on motor tilt, but at max rpm it is shooting a 6 to 10 foot roster tail so it seems like i'm spinning my wheels so to speak. I will try to remember the gps next time. I have been doing nothing but fishing but when it's right we will try tubing agian.
It seems as if my blades on my prop are narrow but they do have a cup. Does it sound like a 4 blade prop would help my hole shot (or lack ther of) and give me a decent top speed? It feels like I'm moving across the water at 40 mph or so, but I can't bring the front of the boat up to keep from getting pounded in rough water.
Please give me your recomendations.
