oceansbreeze
- May 9, 2005
- 276
My boat was originally fitted with a trolling motor, there's a jack on the fron for it to plug into, and a space in the bow storage for a battery, with the terminal cables there..
Previous owner removed the trlling motor. I was thinking of getting one over the winter, and recently checked out the big selection at Bass Pro shops. They are all rated in LB thrust. (ie 25lb, 35lb, 55lb, etc) (the bow carpet shows discoloration where the motor was and there is a hole drilled where it once was too..)
How do you determine the appropriaie size? Nothing showed up in the first few pages of searches.
Honestly, I've never ever used a trolling motor except for the old tiller style on a canoe. I see the pedals move the prop around in a 360 degree circle. Is this a decent investment to make?
Just looking for thoughts on using them, and determine what size is adequate for my 17 foot aluminum princecraft (about 1700-1800lb loaded) add a few hundred more if pasengers
