arnettjs
- Sep 15, 2008
- 39
All,
I have a 1992 Cajun with a Johnson 115. All has been running well until yesterday. After fishing a good 5 hours, trolling around, the outboard wouldn't start. It was obviously a dead battery and I don't believe I left anything on (other than the two fish finders). There are three batteries (2 12-volt for the trolling, one 12-volt for cranking). It also has a Cabelas ProSport 12/24/36 triple bank charger.
I just put a voltmeter on the batteries w/o the outboard running. I have roughly 11.3 on all three. I topped off the cells (they weren't very low) and checked all connections. Plugging in the charger, the two trolling motor batteries jumped up to 12.5 and the cranking to 13.06.
I'm going to check them with the outboard running on ears but my question is this: How long do you (generally) leave the batteries on plugged in on that charger. I am sure there are a number of factors (such as age of battery, discharge state, etc.) but I've been keeping it plugged in for about 90 minutes or so. I'm thinking this isn't long enough. Note that my lake is small and I don't run the outboard very long (thus it probably doesn't charge the batteries much).
Sorry for the long post, wanted to give as much info as possible.
Thanks y'all!
Jeff
Thanks y'all!
Jeff
