Re: Trim
Des the trim go up when you press the trailer button? If so, it's probably the trim limit switch. If not, could be a bad solenoid or a loose connection. Try jumping the blue wire on the pump to the positive terminal on the battery. If the motor runs, you either have a bad connection somewhere, a bad solenoid or a bad limit switch/wires.
