gene8084
- Sep 29, 2007
- 187
I have a 1974 Mercruiser 888 Outdrive.
Need a little advice on isolating the cause of this problem.
I just completed replacement of the seawater pickup pump. I'm not sure that could have anything to do with my problem but folks always say what did you change...if you say "nothing but..." you look pretty stupid.
Since completing the pump project I find that the stern drive won't stay up after being trimmed up. rrrggg (Iwas so pleased with myself that everything worked when I put it back together)
I checked this morning, ...in about 30 minutes it drifted down approx. 10 degrees. Clearly not holding.
I don't see any leaking outside the boat. (Trim cylinders, hydralic lines, etc.) I haven't crawled back by the transom yet to look for leaks, but I'm guessing I won't find any.
We certainly wrestled a bit getting the lower unit back in place, leaning/lifting etc., but I would not have thought we could damage seals in the trim pump.
Thoughts?
Thoughts?
