I have a 1990 Mercruiser Alpha One Gen I outdrive with the Oildyne trim pump and plastic reservoir. When I try to trim up, sometimes it works and sometimes it doesn't. When it doesn't work, I hear a grunt and then nothing. I then usually have to press trim up about 5 to 8 more times and it will kick in. Fluid is filled to proper levels and the oil itself looks good. I'm looking at the manual page for troubleshooting the trim system now and there are 12 items. I was wondering if any of them could be eliminated since the trim does work at least 3/4 of the time. If not, I'll run through them all but some of them look pretty involved and if there's a common culprit in this situation, I'd like to test that first.
EDIT: Oh and by "manual" I mean the proper Mercruiser service manual pdf that has been so graciously passed around here.
