puddle jumper
- Jul 5, 2006
- 3,830
I have an aluminum boat transom,with a plywood core sandwiched between two outer aluminum shells. I have made up the plywood to go in. My question is how tight should i make the fit. It seems to come down to about a 1/4 inch. With the extra 1/4 inch it seems to fit a little to tight and if the wood swells it could crack the transom. With out the the extra 1/4 inch it seems sloppy. I could shim it with a small sheet of aluminum that is about a 1/6 of an inch. I am using marine grade plywood. Any advice would be appreciated.
