Re: Transom Leak On Volvo Penta
There is no "Boot" so to speak, on a SX transom shield. There is a hose that the cable goes through on the inside of the boat. Make sure the end of that hose is above the waterline, or water will come in.<br />I personally have never seen a transom shield seal start leaking on a boat unless there was problems with the transom or a cracked housing. Have you determined exactly where the water is coming in from? That is going to HAVE to be the first thing you do. You can't just start fixing every thing that you suspect could leak, man, that would cost a fortune.<br />When you replaced the bellows, are you sure you got it in correctly? If not, it could leak and water could still get in. Was there water in the bellows? I have seen the plastic tube for the gimbal bearing grease zirk come out of the transom shield and water get in through the bearing. if this wasn't fixed, you would still get water in the bellows and into the boat.<br />All in all, you MUST find out where the leak is before you can fix it.
