Hi
I have a Tomos 4hp air cooled outboard that has a stop button to kill the engine. I removed the rear panel that the stop buttong was fitted to and then found i had some loose wires. one white wire comes from the stop button and has an eyelet on the loose end but i cant see where it was connected before, the other white wire comes from a plastic connector block under the carb and seems to join a few other sheathed wires and disapears into the engine so i suspect this goes to the coil???
Can anyone with one of these motors please guide me on where to connect these wires so that i can be sure that i have it right as i can not locate a wiring diagram anywhere on the internet.
Thanks in advance
Kevin
Thanks in advance
Kevin
