Motor is a new TLDI 50 with about 15 hrs. Was testing a new prop today and was able to trim out a LOT more than the factory prop at WOT without losing bite. So I'm seeing how far it will go before it blows out and I get up to what looks like 5800-5900 (hard to tell because I was bouncing around a bit) rpm on the tach and run there for just a little bit, then I get a single beep and the RPM goes to 1000. I pulled the throttle back to idle and turned around and the engine is making a lot of smoke out of the exhaust port.
My common sense says this was the rev limiter.. No lights were on, and just beeped once, it's the first thing in the service manual. I shut down and restarted and the smoke cleared after a little bit and it ran fine the rest of the day.
So - Rev limiter kicks in and lowers my RPM, but throttle is still advanced to full, which means the oil pump is also advanced to full, which means extra oil, which means smoke.... right?
I won't do that again. I don't think I'm underpropped, just was trimming the motor too high.
-M
-M
