michaelhedges
- Jul 10, 2006
- 26
I have a 1992 Johnson120tland. After I have lost some power I did the usual plugs and wires. No better. I then aqired a main. book and did a link and synk and tried to check the timing. Restored most of lost power with the L&S. After trying to adjust the timming I noticed that turning the adjustmnet screw will not affect the timming The timming is only off a little at 18 degrees TDC. While adjusting the timming I did get the motor to 4500rpm at the launch but need more help to get it higher than this. Is this the problem?
Any help is appreciated.
