sickwilly
- Jul 9, 2007
- 1,089
I cannot get to 10 degrees BTDC.
I just finished rebuilding my carb and reinstalling it on the boat. Thus, I am trying to do the timing, idle, and mixture.
I have the mixture screw at 1.5 turns out from fully seated.
I put the boat in base timing mode from running a wire from the purple and white wire to the negative ground on the alternator.
I am checking timing by two white lines I painted on the main crank pulley and a little area that protrudes from the block.
When I checked the timing, it was at 55 degrees BTDC. I could see that the previous owner or someone had loosened the distributor and turned it.
When I turn the distributor clockwise, the degrees of advance lower, but the motor starts running really bad. I understand that this is how it should run in base timing mode, right?
In order to keep the boat from dying, I am tightening the idle screw.
Once I got in the range of 25-30 degrees BTDC, if I rev the throttle at all, I get a small backfire through the carb.
I kept pushing on, determined to get to 10 degrees, but eventually I got a backfire through the carb when turning the idle screw.
This is when I decided I need help, or to bring the boat to a real boat mechanic.
Any advice would be appreciated.
