In the process of debugging and tuning my 85hp force. 1987(B) motor. Electronic ignition. I've watched the carb and timing videos, but my motor is a little different, and I'm not the most mechanically inclined.
Initially, I lost spark to #3, and it turned out to be a bad stator. Replaced the stator, spark on all three. Motor is reluctant to start cold. I have to put it in fast idle, and give it a shot of starter fluid (I know. Bad stuff). Once even slightly warm, the motor starts right up. Acceleration is not smooth from idle to WOT. But once above 3500RPM, motor runs well. With the prop I have, at my altitude (5500 ft) my engine max's out at 4800 RPM and runs smoothly and well.
Electric choke works well. Carbs seem to be synchronized well.
I need to fix the low end response, and I think I have screwed up the timing during my "fixing".
On this motor, is the timing tree adjustment low on the engine, near the back of the throttle linkage, or is there a timing adjustment under the flywheel like the 125hp motors? (I don't have the motor close by to check)
I set up the cam adjustment with the ball linkage off (Frank's video), re-attached the linkage, started the motor and adjusted the idle speed using the screw and set nut behind the cam linkage. Now I am thinking that I may have been screwing up the timing.
Questions :
1) It appears that timing is initially set at WOT, for 28 deg, while cranking. Once this mark is set, then I start the motor, at idle, and check / set for idle timing. Is this correct?
2) What is the means to set the idle speed? Do I lengthen the ball joint coupler?
3) If the ball joint coupler is not used to set idle speed, how do I correctly set the length of the coupler?
4) Is 4800 RPM the correct max revolution speed? Or do I need to resize my prop?
Thanks for the help!
Questions :
