L8-Again
- May 8, 2010
- 55
So I am tackling a ram rebuild. I noticed a small leak from the port ram at the aft side and I am ordering a new seal kit. Upon dis-assembly I noticed that there was some gunk build-up and realize the system should be cleaned. However, I was wondering of it is wise to remove the piston nut on the forward end of the ram to disassemble and clean that area too?
The rams also won't stay tilted or trailered without using "ram chocks." Over a period of hours the out drive goes all the way down. I read that there is a check valve in the pump that may be defective. Has anyone taken the valve body apart to clean/repair? (Prestolite pump, black)
1979 Cordova, 260 Mercruiser (Chev 350), SE106 outdrive (Alpha I)
