Tilt trim gauge/ switch help
svoluch
Hey guys I bought a 1900 bayliner 1983 with a 150 hp evinrude. The trim tilt gauge never worked on it. When I turned the key, the gauge would shoot straight to the bottom. But when I moved the tilt trim switch up and down it didn't do anything. So I took oit the gauge and took off the switch and want to see if it just wasn't wired correctly. Could you tell me what the letters stand for? I take it G is ground, - is negative. What about L and S? Any help is most appreciated. Thank you Mikhail
Silvertip
"L" is the terminal to which the "light" wire connects to. This is the same wire that feeds the "L" terminal on all other gauges. It has 12 volts on it when the NAV/ANC switch is in the NAV position. "G" is indeed ground. The wire on the "S" terminal feeds the "S" (sender) terminal on the gauge. What you have in your hand in the first photo is not a switch. It is the trim sender. As the lever moves, the resistance (ohms) between the "S" terminal and "G" terminal should change. Wiring is likely not the issue (although it could be) but rather the sender itself. Here is the test. Disconnect the wire from the "S" terminal on the sender. With the key in the RUN position, touch that wire to ground (unpainted bolt or surface on the engine). The gauge should immediately jump up. If it doesn't, verify there is 12 volts on the "I" terminal at the gauge. If not, fix it. It should get that power from any other gauge. Also verify that the "G" terminal has a good ground (also from any other gauge).
If the gauge has power and ground and the test for the "S" wire at the sender pegged the gauge, then the sender is bad. Using an ohm meter to verify resistance changes as you move the lever will prove the sender is good or not.
