Fully_Loaded1
- May 24, 2005
- 58
Ok I went from a 3 wire setup to a 2 wire setup. I bought a used yamaha 2 wire relay set up and need some help on wiring it. If anyone knows or can look at theirs I would appreciate it. I know the blue and green are the switches for up and down. The 4 black leads (2 from each relay) are grounds. That leaves 2 short red wired with ring terminals on the end and a black and a white wire that go to a seperate little connecting posts. I assume that the tilt trim motor wire go on this. Where do the 2 short red wires go? On to a constant 12 volt source?
