I pulled the prop on this 90's 40HP Evinrude I have last night. Maybe the previous owners never removed it because the splines are somewhat corroded, no grease to be seen. I tapped the prop with a rubber mallet and it slid right off, but the thrust washer is stuck. I need to remove it to replace some seals.
Any suggestions on how to remove it. I've tried heating it a little with a torch, hitting it with a plastic mallet and prying lightly behind it with a screw driver.
