I recently bought a 1984 yachtwin 9.9 long shaft. The teeth on the gears where the throttle assembly meet the motor are stripped and frequently (almost every time) jump when you try to turn the throttle. The teeth are stripped on both sides - at the motor and the throttle. Even when they don't slip, the throttle is very hard to turn. I took off the throttle arm and tried turning the gear on the motor side directly (while the motor was running) - it is very hard to turn.<br /><br />My question is this - can both be replaced easily, and if so roughly how much can I expect to pay for the necessary parts? Also is the difficulty turning the throttle a normal problem or is it indicative of some other problem? Can I just grease up the throttle parts?
