The Revenge
- Jun 1, 2010
- 60
Changing my thermostats. These ports on the housing and inside the neck look really rough. Should I try and sand blast these to clean them up for better water flow? I've never changed the risers also, by the looks of these should I expect the same or worse with the risers? This thing had what looked like a thin paper gasket. Do you guys use the same or go with some type of RTV? Everything here is 5 years old. Thanks
