SuzukiChopper
- Oct 10, 2004
- 782
Hey,<br /><br />I just took a couple pictures of my boat for a question I had about its attitude in the water. I thought I'd snap one more as a teaser for here. The boat's a little dirty from our camping trip and haven't had time to clean it out or make a necessary repair yet, but when that happens I'll snap some more. This picture shows the power tilt and trim from a '76 Johnson that I fitted to my 1972 Johnson (was told it couldn't be done). It also shows the transom work I did (extra 1 1/2" taller in the center section, and raised on either side). You can clearly see where the old transom was by the old glass. If you also imagine the splashwell being a single piece across the boat, angled up from that point to about 2" below the top of the gunwhales, as well as 2" back from the new deck I built, you'll see the extra work I did. That rear deck was all constructed and re-enforced using 2x4's and 2x2's with 3/8" sheeting right infront of the new splashwell (going to put a removable pedistal there) and 1/4" sheeting along the front and sides. On the nearest side is the battery compartment with a flush lid, and on the far side is a storage bin the length of the deck with the same style lid.<br /><br />I don't like how the lids turned out so I'll be re-doing those. Sorry I don't have any in progress pictures but the final result (which is still to come), will say enough. The floor was all re-done, stringers re-done (with extras added for more structure), 19 gallon permanent tank up front (still going to cut open the bow and put a casting platform/trolling motor controls up there), transom replaced, and the rear section completely modified. All of this and if you look below the outside chine where the white tape is, is where the waterline is when it's sitting in the water (toooo bouyant I think now).<br /><br />This winter if all goes well, the open bow will be completely as well as a complete cosmetic overhaul.<br /><br /> The Teaser<br /><br /> Picture showing the waterline when the boat is sitting <br /><br />ps. one last thing, if anyone knows ANYTHING about this boat I have (made by international fiberglass inc.) please let me know
