Re: taking on water
My Bass Boat doesn't get any water in it, that is the ideal situation, when I pull the plug after a all day fishing there is no water that comes out, perfect. But that's not the case for everyone. Even with people coming in and out of the boat you should be getting a ton of water. The best way is, easy if you tow your boat, but I would get it out of the water. Let it completely dry, put in your plug and fill the hull up with water. Just look around and see if you can find were water is coming out. I think most of the time with inboards it seems the seal around where the outdrive and hull is the cause of it, but not always.
