Re: Tachometer question
Silver....I got my tach in!!! (It's a shame how the simpliest things make some people giddy with excitement...anyway). I'm a lil confugled. My tach that I got from Marine Trading Post outta N.Fort Myers Florida is a TuroTest 0 - 6000 rpm tach. On the back, at the top left side it has written TA-S-01 to the right of that is a gold/brass/bronze colored post, with nothing written by it. Under that, towards the left side it has written 1 = 12 Pole Alternator...2 = 4 Cylinder 4 cycle...3 = 6 Cylinder 4 cycle...4 = 8 Cylinder 4 cycle. To the left and a lil below that, it has a lil dial with 1,2,3,4 circling it. The "pointer" is towards the 2. Bottom middle is the 12v terminal...to the right of that is the S terminal..and to the right of that is an abstract looking Christmas thingy (I'm assuming that's the ground). You mentioned up there, in an earlier response to this thread that "You outboard places 6 pulses on the send line for each engine revolution. Therefore that dial needs to be set to "6P"." That's 1 area where I'm confugled. There is nothing on the tach that I have that says ANYTHING about 6p. Also, I got the power line and the line that works my gas gauge hooked to the 12v, which I know is working, cause when I turn the key, my gas gauge works. I have what I know is the ground, hooked to the abstract Christmas tree looking thingy. My 2nd confugledness is I don't know which wire is from the sending unit in the engine! I looked in the Clymer manual I have for my engine (I know, I know...prob not the best), and see nothing about the wire that would be leading to the instrument area what color it is or where it hooks on the engine. I'm thinking that wire might be bad???? If I can find it, I'll just run a new one and that'll be that, I hope. So, basically what I'm asking is...is my tach the one I need and set up correctly...where does the wire come from on the engine and/or what color is it....how do I test the line, other than having it hooked to the tach? Should it have some kinda current on it when the engine is running? I have a 1990 Mercury 115..model # OC247555.
