hunley1864
- May 1, 2011
- 11
Hey fellow boaters I have a problem with my TACH. The Tach needle never moves when motor is running. Heres what I have done I replaced the rectifier ,checked all wire connections to terminal block on motor 1983 johnson 115 hp v-4 . They are all good and correctly connected. I checked the connections to the Tach all good as well and getting power. Also checked voltage at battery 12.45, when motor is slightly rev. volts go to 13.85. I ,thought maybe bad rectifier , is this the correct voltage I should expect. I am trying to keep from spending 65 to 90 dollars for a new Tach unless it is needed. Thanks for any imput. MR. HUNLEY
