115mirrocraft
- May 29, 2011
- 20
just purchased the 5 pin wiring harness for my quick silver control box. The tach I have only has a negative and positive terminal. I connected the purple wire to the + and the grey wire to the - terminal. I then attatched the black wire to the tach mounting bolt to ground itself. I am also jumping power to my fuel gauge from the tach, fuel gauge works and back light comes on. but when i turn the key tach needle jumps to 6000 and stays there. ran the boat in driveway tach moves a little bit but stays in 6000 range. there is also no adjustment screw on tach. it is the round dial type and is black probably original too boat which is a 1985 mirrocraft offshore gl 17'. Do I have the wrong tach or is it something else? any help greatly appreciated. tach also has light in back of it but is missing.
