I bought a used head to replace the bad crank on the one I have. I was going to swap it head for head. The one I bought was suppose to be a 1963. After I got it and looked it over it is very different from mine. It has the cutout switch on the oppisite side and no spot for a fuel pump. I am guessing that it is from an earlier, 1959 and prior, year. My question is will the crank from it work in mine? My motor works but sheared off the woodruff key, it is the third one that has sheared off in the past 6 years, and the piece in the crank is welded to it. And yes I torqued it to factory specs every time. Thanks for the help.
