Re: Swap lower unit on my 150 evinrude
You can make it work. Been there, done that. With the 2:1 ratio in the V4 case, your low end response will be tremendous. You'll obviuosly have to use a V4 prop. <br /><br />Make sure you use the best synthetic gear lube available. That much torque on V4 gears is hard on them. The bigger the boat, the harder it is on them. <br /><br />If it were me, I'd just get the V6 gearcase.
