Yepblaze
- Jun 1, 2001
- 1,686
I have recently acquired an 81 DT85 (8501-001734) as a resurrection project.
Well, it lacked spark, and through diagnostics found it to need a CDI switchbox and a couple of ignition coils.
Now, after replacement of these components I have great spark, but the timing for all three cylinders appears to be about 30-50 degrees retarded. I have indexed and checked the flywheel, it's timing grid, and piston locations to verify and they are all correct.
Upon extensive (well extensive enough) research I find that somewhere in the model range they changed the triggerbase/flywheel as a pair and I may have from some previous owner received mismatched components.
I have seen a difference between my flywheel and it's internal ring magnet, and it's relationship with the keyway by way of a mechanical drawing in a manual,
but have not seen (as of yet) a timer base with the control arm and it's relationship to the 3 pickup coils (yet) with the corresponding difference.
I think I can possibly change one, or the other to correct this issue.
I have called around looking for parts and most suppliers want to sell the pair for about $300. this is currently way out of the budget for this motor after already dropping $200 for the CDI and coils.
That and I still have no confirmation that the timing variance is actually a parts mismatch.
I'm including a couple pics of what I have at hand.
Perhaps someone has dealt with this issue, can shed light on this, or has a motor in the bone yard with parts available at a very reasonable cost that I can acquire to help me correct my issue. yepblaze@hotmail.com
These components (by way of my research) are somewhat compatible between the dt75 and dt85 through about 1980 and about 1984.
