CaptainD101
- Jun 15, 2010
- 91
hey guys another motor to my collection and another question if any one has some advice. This is a Suzuki 90 hp early 90's v4 with the mukuni double barrel carbs. I pulled the carbs for a thorough cleaning as the motor has been setting for a year since being run. Put back together and bypassed the oil injector to run mix gas now. Turned idle needle screws( rich/ lean screw) to about 1 3/4 turns out from seated and cranks instantly with the choke and sounds very strong. Buutt.. just a bit to strong I would guess about 400- 500 rpms to high at idle.
There not many adjustment screws that I see. Theres the screw at the top of the throttle linkage but that adjust the butterflies at idle but its back off all the way, when i screw it in the idles higher. Besides that there's just the idle adjustment screws that I set according to my mercury experience, but what is it for these mikunis on the suzuki
heres the video of it running
http://youtu.be/3hvVyPqr9VE
