Have a 3 year old Suzuki 2 stroke since new. Cooling water recently will not flow from rubber tell tale under engine head, with engine running, unless the rubber access cover to shift linkage is removed. Water does flowl from tell tale when engine stopped and the flushing attachment inserted and garden hose hooked up.
Installed new coooling water impeller kit with out improvement in water flow from tell tale. Pick up tube from pump to head is clear as is screen for water pickup.
Tell tale access to engine block appears free of salt buildup.
any ideas?
crowley1
any ideas?
crowley1
