Surge Brake Coupler Problem
hibbert6
I just got surge brakes mounted on my boat trailer - cost me $900! (Better of 2 bids.)
The second time I hitched up, I accidentally forgot to flip the tab up whilst lowering the coupler onto the ball. On my previous coupler, no problem - I'd just stick a big screwdriver up there and work it until I got the tang unstuck.
This new surge unit makes getting to the interior mechanics quite difficult. I was finally able to get the tang to give way, but it's never worked right, since. Sometimes, I can't get it to unhitch, and I have to bump the truck back & forth to get the coupler to unhitch. The lever on top doesn't really pop into the "up" position like it originally did.
Any suggestions?
Dave
Bob's Garage
Re: Surge Brake Coupler Problem
Any suggestions?
Dave
Take the couple apart my removing the large nut you will find underneath, holding the "tang" and check for a bend in the lever mechanism. If really bad, replacement is called for but it's likely just a slight bend that's hanging it up.
