clemsonfor
- Sep 19, 2005
- 1,011
I just got back from the lake. I have a 1981 Johnson 60 HP. I ahve had this boat for 5 years or so. Been trouble free for almost 4 years. When i got it it had an intermittant cut out problem (different from current one). I found a rotted wire harnes. I replaced it a cracked coil and the other just to put new ones on it. The power pack was the problem back then. No problems since untill today.
On the lake we were crusing and has a stumble then fine 5 mins latter a few more stumbles then a sudden cutout. Tried cranking and nothing. I dont have a spark on either cylinder checked with a spark tester light and on the water with the old screwdriver method.
I still have the old powerpack that was intermitantly bad. It seemed that when it heated up it totally failed and if it cooled it was fine. So i bolted it up and no spark at all from it. Now its possible that it now totally dont work but its problem was say 5-20 mins of running it would all of a sudden cutout then you would sit for 5 mins and it would start up again, never a problem cold so i think it would at least fire.
I have diconnected the main harness and jumped the starter so that if the kill wire was shorted that would rule that out, but nothing.
Any suggestions of what to check and where to test. Everything except the stator on this motor has been replaced with less than 40 hours or so on it.
-Nate
-Nate
