Well, my 1976 75hp is still overheating. After about 10 minutes the tell tale quit delivering water. I have replaced the impeller (twice) and then the thermostat. The water pump housing looked good and then I ran water from a garden hose up the tube to the top of the block and it apppeared unobstructed as it came out. Then I removed the exhaust cover and it appeared like all the channels were clear. Removed the bypass cover (and of course broke one screw) and the spring and valve will not come out--calcified. Would this cause the overheating issue. I also cranked over the motor in a tub of water, but it would not deliver water to the top of the block outlet. Should cranking produce enough vacuum/pressure to bring the water up? Any ideas would be appreciated!
