Re: Stringers.....Plywood or 1X6?
I normally would not offer advice since so new to boat building, but since I just did this I do have an opinion.
I convinced myself to use dimensional lumber, 2x's, since my stringers are 12' and 14', I thought it was a silly idea to use two pieces of ply joined together, I thought how could that be better/stronger than a 2x6?????/
So,
I used 2x10 // 2x6 high grade dimensional lumber, "no knots", planed to 13/16 thick, let dry for a month, the problem with dimensional lumber-espectially PT-is that it warps/cups/twists badly and is prone to grain length-wise cracking.
I was able to use mine but they indeed did warp, alot, I stop drilled the cracks and filled with epoxy filler-injected.
I would use Plywood next time, with the lap joint method, (Oops thread has a great picture of this) plywood is much-much stronger than any dimensional lumber could ever be.
And I also agree with you on the point of do not be drilling into it, use the cross supports as Ooops has said.
I encased my entire stringer with 8oz cloth first, then glassed it in the boat with thicker 1708, I will not drill any holes in it when installing floors/sole/deck, will use cross supports to screw into and PL the strings down.
Hope that opinion helps.
Dimensional lumber is pretty though-LOL.
Good luck
Lund
