mtduckhunter
- Jan 31, 2008
- 241
ok guys, i need help. im about to start rebuilding the stringers and transom on my 1972 15' monark. i have alot of questions.
should i remove the top cap to rebuild the transom? it looks like it would make it much easier.
if so, how do i go about removing it? is it hard to put back on?
this hull has severe hook, and it drives me crazy when i run wide open and there is a 4 foot wall of water on both sides of the boat and it starts at the bow! so, i am going to TRY to fix this by replacing the stringers. im going to use pressure treated ply that i will let dry. anything else i should do?
and also, should i take the boat off of the trailer and block it up? or build a cradle for it?
any help would be greatly appreciated. i will post pics when i get the deck out.
