Re: stress crack repair?
It can be difficult to repair correctly, and to make sure they don't come back, you may need to dig around inside the hull and check for rotten wood. <br />If they are from a minor impact with the dock or trailer, you may be able to do it from the outside. <br />If the reason for the cracking is unknown, then the cracks will most likely return. If he hull was flexing enough to crack the gel coat, it will do it again unless some changes are made.<br /><br />Thick gel coat can be very brittle and crack easily. <br /><br />I just looked at the bottom of the post, is it the 04 SeaRay that is cracking?
