17'6" Alum deep v, 115 Optimax, boat and motor probably around 2200 lbs.Two people with fishing gear, ice chest, misc. I can hit the rev limiter at wot and max trim, motor is rated to 5750 rpm. GPS speed 44 mph. Begins to porpoise and have to throttle back. From what I have read here have narrowed things down for a new ss prop to a Stiletto. I am using the stock merc alum13 x 17 pitch prop now. Think the motor could handle a 19 pitch Stilleto? Or any other recommends.
Had severe porpoising probs, raised motor and that helped the porpoising problem but did not eliminate it. Not comfortable with raising motor another hole since I am maybe two inches above keel now. Water pressure is good where its at. Ventilates very easy in moderate turns, porpoising still a bit of problem. Think a ss prop might help with those two things plus maybe a little better all around performance?
