wil7483
- Jan 19, 2007
- 377
Re: Sticky situation
When the drive was put on last year it slid in like snot on a doorknob. And yes I do have the proper tool and all. Thanks.
I'm changing the u-joints so I went ahead and removed the yoke from the drive and will take it to a friend to cut the inner race free. I decided to just buy a NEW bearing puller so once it arrives I will try once again to get the remain bearing out so I can see if the housing was damaged.
Wil, did you do a proper alignment last year with the proper alignment tool?even if so maybe check your rear engine mounts when you pull the motor.just a thought.
