Hey everyone I have a 1989 19’ tempest it have a 4.3l and alpha 1 drive
I recently replaced the engine due to a cracked block
the problem I’m having is. I can’t for the life of me seem to get the back of the engine and the gimbal housing to line up In order to install the out drive
I have adjusted the front engine mount nuts from as far Down as the will go to as far up as they will go ( no thread left ) and it seems no matter what I do the back of the engine is sitting to high at the back I’ve been using an alignment tool but it gets jammed up and will only go in an inch or so
im at a loss as what to do or look for The back of the engine is sitting flat on the gimbal housing bracket ( if that’s what it’s called
any ideas what I’ve done wrong or things to check would be greatly appreciated
