I installed a CD player in my boat. Everything is hoookedup correctly- now when I increase the volumn-my continuous hot fuse blows (1.5A) It is a 99 bayliner-I have checked and all voltages read correctly-There are 2 hots. one is continuous and the other is present when the ignition switch is turned on-I wired the continuous hot by the color code, and ir should only power the memory right? I cannot understand how the volumn has anything to do with it- the other hot does not blow- but I lose main power. Am I chasing a bad ground? any ideas?
