FourWinnsLC
- May 28, 2012
- 59
I recently installed two 6x9's and two 6.5's JBL speakers, a self amped Sub(JBL) with a 600 watt Rockford Fosgate amp and a newer sony Radio (Forget model) I am having issue's with the speakers cutting out, I bought the rockford fosgate amp for the single fator that the amp was going to be in the cuddy where it's going to get hot. After reading ten thousand reviews and forums the rockford fosgate amp handled the heat better. My thinking is I am not getting enough power. It does not matter if the boat is running or not. any idea's? I know I am not the only one that uses a set up similar to this one.
Right now the boat has two batteries (Deepcell Starting batteries) The thought was to wire everything into one battery and use one battery while the boat was off so you could still have one battery to start the boat in case the one playing the radio went dead.
I appreciate any information.
Also I used 4 gauge wire to wire the amp.
Thanks,
Mike
Thanks,
Mike
