Re: steering help please
two things come to mind:
If it is hard to turn and your fighting the steering wheel, could be prop torque, usually easy to turn one way, like a car needing an alignment pulling to the right or left.
secondly and most likely is improper trim. Im a pretty new boater and trim was something you had to learn as you go and every boat is different. Im guessing since you get on plane your not trimmed in too much. if you never trim out you bow is gonna stick up in the air untill you get enough speed. if you were infact trimmed in too much all the time, you would have pretty good steering, once you trim out (raise your out drive up and out) you will loose percision in steering and the boat will float a bit, take your boat out and try not to trim out so much see if it helps.
when moving thru the no wake zone i trim out a lot so i dont "zig zag" and will move in a straight line since my steering is less sensitive.
